- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Transmission Type
- Manual
- Mods-Bolt-on
- 20g, 3inch exaust,jdm fmic,2.75 inch intercooler pipes . Dual intank wallys. -6 feed fuel line,aftermarket fuel pressure regulator.
- Mods-Engine
- Six bolt block, wiseco 9.1 eagle h beams rods combo, acl rod and main bearings, oem new oil and water pump, polished crank and balanced,
1g head with dual valve springs, ss valves, revised lifters, evo cam gears, hks 272 cams, arp head studs, cometic head gasket.
- Mods-EMS & Logging
- Ecmlink v3 on sd, 1600cc injectors, boost by gear controlled by ecmlink,aem wideband
- Mods-Drivetrain
- none
- Mods-Handling
- h&r springs with tokiko 5 way adjustable strusts, 3000gt front calipers and rotors upgrade.
- Parts Wishlist
- Awd swap (closer than what i think it is)
- 1/4 Mile E/T
- 15.010
- 1/4 Mile MPH
- 127.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : E85
Vehicle Weight : 3200
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 383.3 lb/ft
- Dyno Type
- DynoJet
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : E85
Turbo : 20G
Boost : 32
