- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- ETS FMIC kit
Greddy type F /V bov to atmosphere
Megan racing downpipe and 3inch exhaust turbo back.
Evo 3 Big16g Mitsubishi
AC delete
Powersteering cooler delete
880PTE injectors
Fuel Lab FPR
Fuel Lab metal fuel filter
Walboro 255 fuel pump
Battery relocation to the rear
Street Wires 3 farad capacitor in front
PCV inline vented catchcan
vc breather sealed catch can
Stainless steel oil feed line from Extreme Psi
- Mods-Engine
- 6bolt stock rebuild with Crower 264 Stage 1 cams, supertech springs and retainers and ARP headstuds. Mitsubishi Headgasket. OEM rebuilt components - a few gates parts(water pump, belts, gaskets, thermostat)
NGK 7BPRES .29 Gap
NGK wires
- Mods-EMS & Logging
- ECMLINKv3
Phantom boost gauge + AEM digital fuel ratio gauge on dual gauge pod.
Glowshift oil pressure and oil temp gauge.
- Mods-Drivetrain
- 3bolt rear, stock tranny tcase +diff with redline lightweight for tcase and diff and bg 2 for tranny. Clutch is ACT streetlight 6 bolt flywheel and clutch.
Rebuilt clutch pedal assembly with welded nut from JNZ tuning.
Replacement OEM pivot ball + clutch fork
STM extended slave rod
- Mods-Handling
- KYB REAR/stagg FRONT struts with ebachi pro 2inch lowering springs, adjustable camber rear control arms, front adjustable camber bolt kit. Moog end links, tie rods, and ball joints. Hankook 225/40/18. Drifz rims 18x8.5
- Parts Wishlist
- Paint job + maybe methanol
- Background
- Bought from a local dsmer NOV 2012 who got the car from his friend who worked at a mitsu dealership in milwaukee. Previously had the 92 front end conversion done.
This car is nearing completion with a tune setup for December 1st at Boostin Performance and paint possible before or not to long after at Rodell Auto Body
Videos
My system
my subs on my 1992 eclipse. 2 jvc 600w rms arsenals on a 800w rms fosgate 2ch amp. i have 2 6x8 sony explodes in the back, 2 kenwoods in the front and 2 jbl's in the dash hooked up to a 500w 4ch xplode
clutch line thread problem
clutch line wont thread
