Please Support Ace Race Parts
DSMer541's Eclipse GSX
  • Ownership Status:
    I own it
    Year:
    1997
    Model/Trim:
    Mitsubishi Eclipse GSX
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    FP Black Turbo / FP exhaust manifold / Punishment External dump o2 housing / Tial MVS 38mm V-band waste gate / 3" down pipe to 4" exhaust with Vibrant muffler / JMF Race SMIM / 70mm S90 tb / ETS 4" short-route intercooler / aluminum 2.5" piping / STM 4" intake / Tial Q 50mm bov / Fuel Lab AFPR / walbro 450 E85 pump w- rewire / FIC 1800cc injectors / Jegs filter / -6an fuel feed line / Mishimoto radiator, hoses, slim fan, shroud.
    Mods-Engine:
    2.0L 6 bolt / Wossner 8:1 pistons / Eagle H-beam rods / Mitsu MLS head gasket / A1 Head studs / HKS 272 cams / JAM stage 2 CNC P&P cylinder head / JAM +1mm valves / JAM dual valve springs / Ti retainers / Bronze guides / JAM shorty viton valve stem seals.
    Mods-EMS & Logging:
    ECMlink V3 / Speed Density / Flex Fuel / Ingersol 3 port boost solenoid / AEM analog WB / AEM analog boost gauge / Omni 4-bar MAP / GM IAT / Glowshift Elite series Water temp, oil presure, fuel pres.
    Mods-Drivetrain:
    Jacks Drag transmission w-EvoIII 1st and welded center diff / Comp Clutch Stage 4 - sprung 6 puck / Fidanza aluminum Flywheel / Torque Solution motor mounts / STM master-to-slave steal braided clutch line / solid shifter bushings
    Mods-Handling:
    D2 coil over suspension / Toyo Proxy-4 plus 235-45 tires
    Parts Wishlist:
    carbon fiber parts
  • FP Black Turbo, JMF race intake manifold 605/475
    FP Black Dyno, stock intake manifold
    11.31 @ 131 Forced Performance Black Turbo on E-85
    Sport Compact pro class @ Woodburn drag, round 1 elimination race.
    Round one of eliminations in the Sport compact pro class ( April 27 2013 ). I dialed in at 12.15 and ran a 12.19@116.38 with a RT- .116, and got the win, but then lost the next round.
    DSM doing a doughnut in the sand
    just out on the beach with some fellow dsm'ers havin some fun in my GSX...
    personal best run of 11.9
    just a test & tune run, but a good one.
    IFO 11.96@118.6
    Import Face Off 9/1/13 at Woodburn Drag Strip. This was my best pass of the day, in full street trim 3200 lbs w/me. 20G TD05H .
    60ft- 1.71
    1/8th- 7.71@93.22
    1/4 - 11.96@118.67
Share this Item
Chumpaumpalumpa and er82 like this.
User Comments
To post comments, simply sign up and become a member!
  1. Vegas smith
    How is this car doing? Has the black held up well?
Log in/Register to remove ads
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
