dsmdeliveryboy's Talon TSi AWD
Eagle Talon TSi AWD
Turbo Lab billet hx40pro, DragNFly tubular manifold with Tial 44mm gate, 3" o2 housing by DragNFly, 3" catless straight pipe turboback exhaust with magnaflow race muffler, VRSF short route fmic, Tial 50mm bov, FP 4" intake pipe, walbro 255 double pumps, 1100cc high z injectors, battery relocated to trunk with sealed box amd certified kill switches,, fuel pump rewire, emissions deleted.
Mods-Engine
HKS 272/272 cams, rebuilt head, balance shafts eliminated, ARP headstuds, cometic HG, Gates kevlar timing belt, Evo 8 springs, titanium retainers, ROSS 8.3:1 pistons .20 over, Eagle rods, ACL race bearings, ARP hardware.
Mods-EMS & Logging
DSMlink V3, boost gauge, EGT gauge, Innovate LC1 wideband, omni 4 bar map sensor, gm iat, electronic boost control solenoid
Mods-Drivetrain
TRE transmission rebuilt by Turbo Lab and Tru*Function, 4 bolt rear end, billet shift forks, ACT 2600 pressure plate, ACT 6 Puck Sprung clutch disc, ACT XACT streetlite flywheel, Jacks Racing clutch fork and fulcrom ball, solid shifter bushings, stainless clutch line.
Megan Racing coilovers with front camber plates, beefy sway end links, 3sx adjustable rear control arms, front and rear upper strut tower bars, custom brake lines, rm sway bars, 3000GT SL front brakes, brembo blank rotors in the front, brembo slotted rotors in the rear.
Parts Wishlist
Wider tires(atleast 255's),, kw variants, roll cage, dogbox trans, sheet metal intake mani
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : yes
0.0 lb/ft
Dyno Type
Mustang Dyno
Dyno Session Details
dsmdeliveryboy
More in 1G DSM
Share this Vehicle
