dragonov_elite's Eclipse GSX
Mitsubishi Eclipse GSX
Redjack Twin scroll T3 manifold and custom down pipe 3", Holset wh1c TS T3(54mm compressor inducer) (hotside 16^2cm), 4" FP intake, FMIC kit, Greddy type S, 3" Apexi Dunk exhaust, 65mm 1g TB with FIAV and half shaft mod, Poly Motor and transmission mounts, Magnecore 10mm wires(NGK bpr7es plugs), Walboro 255, FIC 1050cc Injectors, STM AFPR kit, Evo 3 OFH and oil cooler.
Mods-Engine
Ported and polished head, kiggly beehive springs, SIM 275 reground cams, 3mm over sized lifters, L19 head studs.
Mods-EMS & Logging
Ecmlink v3, Electronic boost controller via v3, Omni 4 bar map sensor, IAT sensor, Prosport digital gauges (wide band, boost, oil pressure, oil temp, water temp)
Mods-Drivetrain
ACT street light flywheel, South bend dxd-s PP, South bend TZ clutch disk, Solid drive shaft bushings.
Eibach pro's springs and Tokico shocks (illumina), and Ingells camber kits, Evo IX 17/8 rims.
Parts Wishlist
Magnus cast intake, ETS Fmic kit w/short rout piping & cast end tanks, shep stage 4 trans, 6pt roll bar, Tial BOV, Coilovers!
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
dragonov_elite
More in 2G DSM
More from dragonov_elite
Share this Vehicle
