- Year
- 1998
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- Injen 4.5" Intake, EVO III Big 16G hybrid (sneaky pete style), DNP Mani w/ 4-Ply Gasket from Evo 8/9, 3.5"(Partial Step Down to 3") Turbo-Back Exhaust w/ SS Atmospheric WG Dump (Customed with HahnRacecrafts 02 Housing), -6AN SS Fuel Line (Entire System), AeroMotive Fuel Rail, PTE 1250's, Walbro 255HP w/ Rewire, AeroMotive A1000 AFPR, FuelLab FF, NGK Plug Wires, BPR8ES Plugs, Spearco FMIC with 2.5" GReddy/Custom Piping, GReddy Type RS BOV, Aluminum Radiator, Pull/Push Fans (SPAL), Samco Radiator Hoses, Mocal PowerSteering Cooler, Hayame Complete Dress Up Kit, Adjustable Hood Struts, Halo Headlights, CC Removal, 2GA Side Skirts
- Mods-Engine
- Forged is all I am saying...
1g BIG rods with 2g Pistons (Mahle), Mach V MBDAC kit,
Mach V Stage 3 Head, 2.5mm crank scraper, Custom Valvetrain, 3G Lifters, Evo Exhaust Valves, ES Red Poly Motor Mounts, HKS 264/272 (Int/Exh), Venom Cam Gears, Kevlar Timing Belt
- Mods-EMS & Logging
- DSM Link V3 with Evo MAF, Apex'i AVC-R, Megan Boost, GReddy EGT, AEM UEGO WB, Megan VoltMeter, Autometer Oil Pressure, Autometer Water Temp, Aeromotive Fuel Pressure Gauge, White Euro Reverse Gauges, LoTek Triple Pillar Pod (Tan), Autometer Dash Bezel, Custom Center Vent Gauge Bezel
- Mods-Drivetrain
- ACT 2600 w/ ACT Xact Flywheel, MachV SS Clutch Line, Custom Short Throw Shifter, Symborski Shift Kit, Speed Source Brass Shifter Cable Bushings, Custom Trans (Built by Me) (Basically a mild rebuild with a taller gear somewhere inside :)
- Mods-Handling
- SusTech F+R Swaybars (Set on understeer setting), KYB GR-2 Struts, Eibach Prokit, ES Master Bushing Kit, Aspirated Performance Diff Bushings, F+R Camber Kits, FU+RU Strut Bars, Baer (Fronts) w/ Evo 9 (Rears) (Full Setup; Pads, Rotors, SS Lines, Speed Bleeders), Enkei GF1s (Anthracites), NITTO NeoGen Tires, Vortekz Generators (I know, but they work and my cosmetics factoring)
- Parts Wishlist
- Aftermarket LSD's (Center and Rear), Raxles CV Axles, Aluminum or CF driveshafts, COP Setup
- 1/4 Mile E/T
- 14.178
- 1/4 Mile MPH
- 92.980
- 1/8 Mile E/T
- 8.966
- 1/8 Mile MPH
- 46.490
- 60' Time
- 1.881
- Timeslip Details
- Track Name : Jacksonville Raceways
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3385
Tires : Street Radials
Altitude : 0m
Sponsored Car : no
- Dyno TQ
- 214.0 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Mitsubishi Factory Settings
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : T25
Boost : 10
