crazytsiawd's Eclipse GSX
Mitsubishi Eclipse GSX
3" thermal exhaust●
custom downpipe●
aeromotive fuel rail●
aeromotive afpr●
walbro 255 fuel pump●
PTE 880cc fuel injectors●
rewired Fuel Pump●
sparktech cop system●
m&w Pro-12 CDI Ignition Box●
FP intake●
k&n 9" filter●
FP HTA GT3582R●
FP exhaust manifold●
FP o2 housing (recirculated)●
tial 44mm MVR wastegate●
turbonetics godzilla bov●
Flex a lite slim fans●
koyo aluminum radiator●
dual oil catch cans●
magnus smim●
B&M oil cooler●
spearco fmic 12"x24"x3" w/ 2.5in short route piping●
aquamist HFS3 direct port meth injection●
1g 63mm throttlebody●
optima redtop w/ remote posts
Mods-Engine
6 bolt 2.3 stroker●
eagle crankshaft●
wisco HD pistons with ceramic coated tops●
eagle rods●
.20 over●
acl bearings●
kiggly main girdle●
skunk2 cam gears●
crower 272 cams●
crower Valve Springs●
crower Retainers●
ferra SS Valves●
arp head studs●
cometic head gasket●
greddy Timing belt●
balance shafts removed
Mods-EMS & Logging
vi-pec v44 ems●
AEM UEGO wideband●
aem oil pressure gauge●
aem water temp gauge●
aem tru boost gauge●
aquamist methanol gauge
Mods-Drivetrain
B&M short shifter●
ACT 2600 clutch w/ kevlar disc●
fidanza lightened flywheel●
shep stage 3 transmission/ evo3 first gear, 4 spider center diff
tokico adjustable shocks●
ground control coil overs●
hawk HPS brake pads●
front upper strut bar●
poly urethane motor mounts●
evo8 brake kit front and rear●
15mm wheel spacers with extended studs●
18"x8 ASA wheels w/ 225x40xR18 BFG street radials●
rear camber kit
1/8 Mile E/T
7.511
1/8 Mile MPH
94.230
Timeslip Photo Link
Timeslip Details
Track Name : Castrol
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3200
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
crazytsiawd
More in 2G DSM
Share this Vehicle
