Please Support Rix Racing
codeofdastreets's Talon TSi AWD
Eagle Talon TSi AWD
punishment racing t4 mani and hotkit , fp hta 3582r t4 86ar turbo, jmf race intake mani, s90 throttle body, ets 4in race intercooler, 3 dp dump, pte 46mm wastegate, avid engine mounts, pte1200cc injectors, -8 feed and 6- return, 7 gallon fuel cell, a1000 fuel pump, a1000 fpr, aeromotive fuel filter, fic fuel rail, tial bov,
Mods-Engine
6 bolt motor, custom wiesco 9.5.1 hd pistons, pauter x beam rods, acl race bearings, fully ported head, supertech dual spring and retaniors set to 115lbs, supertech 1mm coated valve, evo 9 roller rockers, gsc s3s, feltpro premortoque hg, l19 head studs, stm balance shaft delete kit, oem front case, straight cut oil pump gears, oem oil pump, oem water pump, oem timing belt
Mods-EMS & Logging
aem ems, autometer ultra pro 45psi boost gauge,autometer ulta pro oil pressure guage with warning light lc1 wide band, shift light
Mods-Drivetrain
Rebuilt trans with welded center diff, clutchmaster twin disk, shifter box bushings, transmission cable bushings, solid drive shaft bushings
Kyb agx"s, ground control coilovers with custom spring rate's, energy suspension polly control arm kit, rx-7 rims, 225/60/16 street tires
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
codeofdastreets
More in 1G DSM
Share this Vehicle
