- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Drag Race
- Mods-Bolt-on
- • Master Power Turbo A/R .70 Model #802136
• TiAL 50mm BOV
• 1G Throttle Body
• Magnus Intake Manifold
• DNP Exhaust Manifold
• Front Mount Intercooler
• Custom Aluminum Intercooler Piping
• Fuel Injector Clinic 2150cc Injectors
• Twin Quantum 380 LPH Inline Fuel Pumps
• 8an Stainless Steel Braided Fuel Line
• 6an Stainless Steel Braided Return Fuel Line
• Russell Inline Fuel Filter
• AEM Fuel Rail
• Aeromotive Adjustable Fuel Pressure Regulator
• TiAL 44mm Wastegate (Large blue + Small Blue 23psi Spring)
• Prothane Driver Side Motor Mount
• Prothane Passenger Side Motor Mount
• Solid Aluminum Front Motor Mount
• Solid Aluminum Rear Motor Mount
• Aluminum Radiator
• Twin Spal (30101522) 12” Radiator Fans
• Battery Relocated To Trunk
• Custom Catch Can To Top of Valve Cover Setup (10an Stainless Steel Braided Line)
• NGK Spark Plug Wires
• NGK BP8ES Spark Plugs
• Dynatek ARC-2 CDI
• CNC 412 Hydraulic Staging Brake
• 3g Brake Booster
• 3g Master Cylinder
• Custom Side Exit Exhaust
• 10an Stainless Steel Turbo Return Oil Line
• Vacuum Canister
• Fuse Box Relocated
- Mods-Engine
- • E85
• Ny-Trex Nitrous Kit (50 Shot)
• Zex Nitrous Purge Kit
• Brian Crower Cams 280/280
• Ferrea +1mm Valves
• Ferrea Valve Springs
• Ferrea Valve Guides
• Ferrea Valve Seals
• Ferrea Valve Spring Retainers
• ARP L19 Head Studs
• Cometic Head Gasket
• Je Pistons + .020
• Eagle Rods
• ARP Main Studs
• Balance Shaft Eliminator Kit
• Stock Crank
• Clevite Main Bearings
• King Rod Bearings
- Mods-EMS & Logging
- • ECMLink (V3) Speed Density
• ECMLink OmniPower 4 Bar Map Sensor
• ECMLink GM IAT Sensor
• AEM Wideband
• AEM Boost Controller
- Mods-Drivetrain
- • FWD Manual GS-T Converted to AWD Auto
• Fully Built Transmission (IPT Transmission)
• IPT Torque Converter (High Stall)
• TransLab Shift Kit (High Performance)
• Transmission Oil Cooler (10an Stainless Steel Braided Lines)
• Transmission Oil Cooler Fan
• Welded Center Differential
• Welded Rear Differential
• Front Differential Locker
• Strickly Performance Axles
- Mods-Handling
- • Evo 8 Wheels
• Hankook Ventus R-S3
• Brembo Evo 8 Front Calipers
• Brembo Evo 8 Rear Calipers
• EBC Yellowstuff Brake Pads
- Parts Wishlist
- Borg Warner S400
