- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- T4 Borg Warner s366
True Street Tuning and Fab t4 manifold
x2 Tial 38mm wastegate
Grimmspeed mbc
Dual wally 255
-10an fuel feed line/-8an fuel return line
RCI high-z 2200cc injectors
Aeromotive afpr
Summit fuel filter
Aluminum radiator
2x 12" slim fans
custom ducting
True Street Tuning and Fab front cross member
- Mods-Engine
- 2.3 stroker
Manley H beam rods
Ross 9:1 pistons
100mm OEM crank
arp mainstuds
arp rod bolts
bse
ACL bearings
arp L19 head stud
Fluidampr harmonic balancer
Poly urethane motor mounts
MAP ultimate duty springs
evo retainers
SS valves
Delta K272
Unorthodox cam gears
- Mods-EMS & Logging
- AEM UEGO
DSMLink v3 SD
Omni 4bar MAP
GM IAT
ProSport EVO boost, water temp, and oil pressure gauges
- Mods-Drivetrain
- Forced Four basic 2 shift box
Kiggly flexplate
IPT end clutch kit
welded center diff
True Street Tuning & Fab mustache bar
- Mods-Handling
- front and rear upper strut bars
K sport coilovers
94 front big brakes
16" FD wheels
