- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- PTE 5031RE l TiAL 38mm WG l FIC 950s l Aeromotive AFPR / SS lines l 1G TB no FIAV l JMF SMIM l Walbro 255 rewired l Earl's 19-row external oil cooler -8an ss lines l 3" JJ turboback l FP Bronze Race Manifold l JMF polished heat shield l FP recirc. intake pipe w/ 4.5" K&N filter l Hallman MBC l SSAC Big 2G FMIC kit l Forge BOV l SHARPHID.com 5000k plug-and-play HID's l Snow Performance 2D methanol kit l Liquidpowdercoats.com powdercoat work l Visteon racing radiator l too much more to list...
- Mods-Engine
- 6 bolt +.020 Eagle/Ross 8.3:1 l ACL tri-metal main and rod bearings l ARP headstuds/rod bolts/main studs l BSE l BC 280/280 l Mitsu. Composite HG l Brian Crower Valvetrain l 5 angle valve job l bronze valve guides l Ferrea valve seals
- Mods-EMS & Logging
- DSMLink l Autometer Cobalt 52mm Water Temp, Oil Pressure, and Boost l AEM UEGO
- Mods-Drivetrain
- Symborski shift kit l Solid shifter bushings l Prothane side engine mounts l 'biglady mod' - aluminum front/rear mounts l SS clutch line l ACT 2900 w. street disc l ACT Streetlite flywheel
- Mods-Handling
- B&G gen 1 coilovers l 17x7 Exel Gunmetal Exel Mimi rims (powdercoated wrinkle black with a white lip) w/ BFG KDW2 235/40
- Parts Wishlist
- T3 setup
