- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- PTE dual BB SCM-5031 turbo converted to T3 .63 A/R..Magnus SMIM..304SS ramhorn T3 tubular exh. manifold..TiAL 38mm wastegate..Modded Accord 3" intake..JDM 60mm throttle body..A'Pexi TT..Turbo XS HP-MBC..rewired Walbro 255HP pump..PTE 1000cc injectors..Aeromotive AFPR and -6 AN fittings..12" SPAL pusher fan..GReddy Type-s BOV..3'' RNR o2 eliminator turbo back SS exhaust..ARC FMIC with custom 2.5" mandrel bent aluminum pipe turbo to TB..rear mounted battery..100% complete '99 GSX conversion, both interior and exterior (25 hp!!).. HID retrofit with bi-xenon projectors..Energy Suspension motor mounts..Setrab external oil cooler w/-8AN lines..Varex adjustable dual chamber sound control muffler
- Mods-Engine
- Full 6-bolt swap .020 over..Eagle rods..Weisco 9:1 coated pistons..ARP headstuds..BSE kit..Ported and polished 1g head..Webcam dual valve springs w/Ti retainers..Ferrea 1mm OS valves..264in/272ex cams
- Mods-EMS & Logging
- DSMLink v3 running Speed Density with an AEM 5 bar MAP sensor..AEM Wideband O2..Prosport digital boost/oil pressure/water temp gauges
- Mods-Drivetrain
- ACT streetlite flywheel..ACT 2600 clutch..built TRE trans w/taller 5th gear..Braided stainless clutch line..Jacks Transmissions transfer case..Baer Big Brake 13.1'' front kit w/2 piece drilled/slotted rotors and aluminum hats..AEM Big Brake rear kit..SS brake lines on all 4 corners
- Mods-Handling
- Adjustable Ground Control coilovers..Koni Yellow adjustable struts..Adjustable camber..Front and rear upper strut bars..235-40-18 Sumitomo HTR ZIII tires
- 1/4 Mile E/T
- 11.866
- 1/4 Mile MPH
- 120.750
- 1/8 Mile E/T
- 7.690
- 1/8 Mile MPH
- 95.080
- 60' Time
- 1.825
- Timeslip Details
- Track Name : US 131 Motorsports Park
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3450
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 368.2 lb/ft
- Dyno Type
- Mustang Dyno
- Dyno Shop Name
- Speed Industries, MI
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : DBB 50-trim
Boost : 30
