- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- AEM cam gears, PE timing belt, copper exhaust gasket, Tial 44mm MV-R, Deatschwerks 320 fp, Blitz turbo timer, Evo MAF, home fabbed SS DP to cat-back(cat-less), black wrinkle valve cover, -8 vc lines to -10 intake, dual tank catch can, Southbend clutch, quad tank fmic, dual Greddy type-s, homemade intake, Carbon fiber CSL hatch
- Mods-Engine
- Fp hta 3176, fp manifold, fp true 3" o2 v-band housing, Eagle rods, Wiseco pistons, ARP's everywhere, MC HG, BS eliminated, 1mm OS valves, smoothed combustion chamber, bronze guides, ported in. & ex. ports, 3g lifters, oil port mod 1 and 2, BC springs & tit. retainers, intake phenolic gasket, HKS 264/272, RCI fuel filter, 1150's, RCI FPR, 6AN fuel system, ARP manifold bolts, FFOFH, oil cooler. Engine bay shaved and tucked
- Mods-EMS & Logging
- triple gauge pod, dual center bezel pod, boost-oil-egt-fuel press gauges, iphone GL1 & dash command, 95 eprom link v3 full, innovate mtx-l, Turbosmart eboost controller
- Mods-Drivetrain
- ACT 2100, Southbend clutch, chromoly Flywheel, SS clutch line, symborski shift plate bushings, Evo 9 MR trans fluid
- Mods-Handling
- Tokico illumina 5 way shocks & springs 1.75 drop, Evo Brembos, RM front & rear sway bars, urethane suspension bushings everywhere, ABS delete, Front &rear strut bars
- Parts Wishlist
- DSS drivetrain stuff, Tranny with evo 3 gearset
- 1/4 Mile E/T
- 16.140
- 1/4 Mile MPH
- 88.050
- 1/8 Mile E/T
- 10.340
- 1/8 Mile MPH
- 69.790
- 60' Time
- 2.062
- Dyno TQ
- 186.9 lb/ft
