- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Automatic
- Build Type
- Drag Race
- Mods-Bolt-on
- Holset HX35 ~ Holset 16cm Housing ~ Punishment Racing Twin Scroll Manifold ~ 4” Side Exit Exhaust ~ Twin 44mm Wastegates ~ FM Intercooler ~ 6” Air Filter with 6” Velocity Stack ~ 4" Intake Pipe ~ Walbro 450 re-wired Fuel Pump ~ Aeromotive AFPR ~ FIC 1250 Inj~ NGK Plug Wires ~ Prothane Poly Motor Mounts ~ AC Delete ~ ABS Delete ~ Alt Relocation ~ 10AN Vented VC with Catch Can
- Mods-Engine
- Stock Internal Motor ~ Stock Head ~ GSC S1 Cams ~ 3G Lifters ~ ARP Head Studs ~ Balance Shaft Removed ~ Gates timing belt ~ Mishimoto Radiator
- Mods-EMS & Logging
- DSMLink V3 Full Edition ~ Speed Density ~ Omni 4Bar Map Sensor ~ Innovative Wideband Gauge ~ 0-30PSI Gauge ~ Oil Pres Gauge
- Mods-Drivetrain
- Stock Auto Trans ~ Stock Convertor ~ Forced Four Shifter ~ Big B&M Trans Cooler ~ Autometer Trans Temp Gauge
- Timeslip Details
- Track Name : Centerville. 1000ft Track
Nitrous : No
Fuel Used : e85 (e70 mix)
Tires : Street Radials
Altitude : 350
Sponsored Car : no
