1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
ARFWD's 14B Monster
Year:
1992
Model/Trim:
Mitsubishi Eclipse GST
  • Ownership Status:
    I own it
    Turbo Type:
    14b
    Transmission Type:
    Build Type:
    • Drag Race
    Mods-Bolt-on:
    Extrude hone 1g intake, homemade 2.5" IC piping, SBR monster core, tial bov, turbo lab rebuilt and ported 14B, self ported E316G 7cm housing, home built 2.5" exhaust up pipe, pte780 injectors, external Wally 255lph
    Mods-Engine:
    Eagle rods, Weisco 9:1 pistons, o-ringed block, SS valves, Evo 8 S&R, crower 264/272 cams, UR cam gears
    Mods-EMS & Logging:
    DSM Link v3, speed density, autometer gauges
    Mods-Drivetrain:
    Stock 1g fwd trans with welded 2g diff, Brian Turhune axles, stock flywheel, act 2600 with solid 6-puck disc
    Mods-Handling:
    KYB rear struts, custom koni 1" shorter front struts, Ground control coilovers, All Urethane bushings, adjustable rear pan hard bar. Weld 15x9" fronts 24.5x8" M&H slicks, Weld 17x4.5 rear wheels, 26x4.5" M&H rears
    Parts Wishlist:
    Wildwood brakes front and rear, weld RTS front wheels, ceramic bearings, 3-pc front clip
    Background:
    This is my first dsm. Didn't plan to much for it for a long time. Decided on shooting for the 14B record. Now I want to chase and reset all stock frame records and eventually play with the SFWD Honda guys
  • 1/4 Mile E/T:
    10.677
    1/4 Mile MPH:
    128.100
    1/8 Mile E/T:
    6.874
    1/8 Mile MPH:
    104.490
    60' Time:
    1.608
    Timeslip Details:
    Track Name : Sacramento raceway
    Nitrous : No
    Fuel Used : Race gas
    Vehicle Weight : 2060
    Tires : Slicks
    Altitude : 1700
    Sponsored Car : no
Share this Item
import solutions likes this.
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
