- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- GM MAFT, 510cc injectors, FullThrottle AFPR, AEM fuel rail (with pressure gauge mounted), Walbro 255 lph HP pump.
Galant VR-4 alternator.
Iridium plugs, Magnecor 8.5mm wires, MBC @ 18psi.
3" SS turbo-back (bolt-in cat/race-pipe) w/Thermal muffler.
ACT Flywheel w/ACT 2600--street disk, 4-bolt rear end.
SS clutch & brake lines.
Symborski Shift Kit, Speed-Source trans shift arm kit.
ALL of emissions vacuum spaghetti nuisance removed.
ALL of AC components completely removed.
- Mods-Engine
- Stock motor internals/turbo.
- Mods-EMS & Logging
- Digital Tuning Inc Pocketlogger.
- Mods-Handling
- 2" drop with Sprint springs, with front & rear camber kits, KYB AGX struts.
Front & rear strut tower braces, front & rear poly sway bar bushings. Suspension Techniques 1" rear stabilizer bar.
Exel Mimi 17x7 (+35mm offset, 17lbs) wheels, hubcentric rings, Ventus Sport K104 tires.
- Parts Wishlist
- Ball-bearing turbo (48+ trim) + all supporting mods.
Quaife center and front LSD in TRE-built transmission.
Kaaz rear-diff LSD.
HKS 264/272 cams.
Fidanza cam gears.
U.R. pulleys.
CF/FB hood.
2.3 L.
AEM ECU.
Aluminum driveshaft.
Fidanza axles.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
