Street Build '99 Spyder GS
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder N/T
Drivetrain
FWD
Automatic
Build Type
  1. Street
Leather Seats
Interior Sound Deadening
Fog Lights Auto-On As DRL
Lighted Taillight Center Section
Convertible Top Boot Cover
Mods-Engine
2.4L 4G64 Built by Aaron's Precision Machine, Blueprinted. Precision machined rotating assembly, Decked Block, Decked Head, Ported Head, Ported Intake Manifold, 10.25:1 c.r.
62mm 1G Throttle Body
Fresh Air Ram Induction Intake
Knock Sensor
Adjustable Fuel Regulator
Stainless Steel 4-2-1 Header & Downpipe
Custom 2-1/2" Stainless Steel Exhaust
Vibrant Stainless Steel Resonators and Twin Tip Muffler
Sealed Gel Battery
Mods-EMS & Logging
'99 GSX Black Box, Reprogrammed by Shane @ DBP with Ceddy mods, ECUFlash, EVOScan
Mods-Drivetrain
Built Auto by Hage-Kobany, Blueprinted, Hardend Output Shaft, New: Shift Solenoids, Wire Harness, Clutch Packs
Blueprinted Convertor, Stock Stall Speed
3G Manumatic Shifter
ForcedFour Smart 150 Programmable Control Module
EPROM Chipped Reprogrammed TCU by Katz
Auxiliary Trans Oil Cooler
GSX 4-Wheel Disc Brakes
Koni Adjustable Yellow Sport Dampers
Front Strut Tower Brace
GST Rear Lower Control Arms
Rear Sway Bar
Rear Adjustable End Links
Parts Wishlist
Tan Roof Inner Liner
Background
Fully Restored after being rescued from the ravages of the Florida sun!
Dyno Type
Dyno Dynamics
Dyno Shop Name
DB Performance, MN
Dyno Session Details
Tuned by Shane. Auto trans, so he could only do pulls above 4300. Factory black box ecu had virtually no AFR programming in the upper end. Installing the programmable GSX black box ecu allowed Shane to use Ceddy mods and reprogram the entire power curve. There is overall improvement, but especially noticeable above 4500.
DogWhistle
Comments
More in 2G DSM
More from DogWhistle
Share this Vehicle
