1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support Kiggly Racing
Autocross Build 97 GSX AutoX Street Mod Build
Year:
1997
Model/Trim:
Mitsubishi Eclipse GSX
  • Ownership Status:
    I own it
    Turbo Type:
    16g
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Autocross
    Mods-Bolt-on:
    EvoIII 16g, 1g TB, Punishment FMIC, Aluminum Radiator, NGR BOV, Thermal R&D 3"exhaust, RC 1000s, FuelLab 818 Fuel Feed Upgrade Kit, Aeromotive "A1000" AFPR Kit, Rewired Wally 255, E85
    Mods-Engine:
    HKS 264/264, E85
    Mods-EMS & Logging:
    Aem O2, Autometer oil press, temp, boost, ECMLink V3, SoloStorm Data logging
    Mods-Drivetrain:
    Short Throw shifter, SouthBend HD-DXD-B Clutch kit, TRE Rear diff(non-LSD originally with a Evo LSD added and upgraded with the Max Lock upgrade), TRE stage 4 trans
    Mods-Handling:
    Drilled/Slotted Rotors, EVO Brembos, Tubular rear toe arms, tubular rear upper control arms, ProthaneTotal kit, Enkei RPF1 17x9, Bridgestone Potenza RE71R 245/40/17, Feal Coilovers 441 13k/8k, RM Sway bars, smaller steering wheel, VOLK front LCA, Ec17pse Rear upper arm, rear lower arm, rear trailing arm. Enkei RPF1 17x10 +18 with Hoosier A7s 275.
    Parts Wishlist:
    Carbon Fiber Hatch, Lexan Hatch window, Carbon fiber sunroof plug, 2.3L stroker, upgraded tranny w/ lsd's,
  • 1/4 Mile E/T:
    12.166
    1/4 Mile MPH:
    117.000
    1/8 Mile E/T:
    7.85
    1/8 Mile MPH:
    89.52
    60' Time:
    1.788
    Timeslip Video Link:
    Watch Video
    Timeslip Photo Link:
    Timeslip Details:
    Weight: Roughly 3200lbs
    Evo 3 16g at 22lbs
    E85
    No nitrous
    Cold Autocross tires (RE71R)
    Beech bend raceway (Bowling Green,KY)
Share this Item
99OZDSM and slowwhite like this.
User Comments
  1. Jose Cruz
    How much power are you making ? Are you running a stock 7 bolt block ?
    1. View previous replies...
    2. doubleclutch
      Be careful you don't lift the head, supposedly that starts occurring around 22-27 psi.
      doubleclutch, Mar 9, 2017
    3. 96dsmftw
      Forgot to add that I put in ARP headstuds though. Thanks for lookin out.
      96dsmftw, Mar 9, 2017
    4. Jose Cruz
      Sweet numbers ! I'll be running the same set up except with evo scan and I've got hks 264 cams. I'm thinking 18 psi will get me 300 hp at least.
      Jose Cruz, Mar 9, 2017
  2. Tuna no crust
    This is similar to the type of build I want to do it looks good .
    1. 96dsmftw
      Thanks
      96dsmftw, Mar 8, 2017
  3. Zcrum123
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
