- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon N/T
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- OBX Header
Cat delete/Straight piped
Spec-D Muffler
Intake with cone filter
- Mods-Engine
- Head:
New stock rockers and lifters
Brian Crower Dual Valve Springs
Stock Cams
ARP Head studs and Cam cap bolts
Bottom End:
Stock
Other:
A/C delete, EGR Delete, EVAP delete, mild engine bay tuck, ECU relocated
- Mods-Drivetrain
- Front/Rear transmission mount urethane inserts
- Mods-Handling
- 16" GST wheels
5mm spacers on rear wheels
- Parts Wishlist
- *Suspension urethane bushings upgrade
*Urethane motor mount inserts
*Plug wires/Coilpack upgrade
*1.5" drop
- Background
- Bought as an empty shell, using the motor and transmission from a rusted out Eclipse along with any other broken/worn part, pretty much combing two DSM's into one.
