- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 14b
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 14b w/ 7cm exhaust housing, DNP header, hard IC piping, Greddy bov, Mishimoto X-Line radiator, Mishimoto fan shroud with dual slim fans, Aeromotive fpr, DeatschWerks DW300 fuel pump, STM fuel pump rewire, FIC 650cc injectors, NGK BPR7EIX plugs.
- Mods-Engine
- BC 272 cams, 3g lifters.
- Mods-EMS & Logging
- ECMLink V3, Innovate LC-1 in rear o2 location (narrowband sim), (LC-2 in front o2 died. Attempting to get it out still), OmniPower 4 bar MAP sensor, GM IAT sensor, Ingersoll-Rand 3 port wastegate solenoid (running boost by gear).
- Mods-Drivetrain
- ACT 2600 6-puck sprung
- Mods-Handling
- Fortune Auto 500 coilovers, rear camber correction kit, 17x8 wheels w/ Sport Comp-2 tires, Prothane master suspension bushing kit.
- Parts Wishlist
- Owned but not on the car yet:
VRSF front mount, On 3 bov, 6 bolt motor (o-ringed block, ARP head studs, ARP connecting rod bolts, Kelford 272 cams, evo springs/retainers, mild port/polish on the intake), Fidanza flywheel for the 6 bolt, Innovate ethanol sensor and gauge.
Wish list:
ID 1050 or 1300cc injectors, V-band manifold (BSF/Archer/etc), V-band turbo (55-60mm range), external wastegate, street/daily friendly bucket seats, sway bars, smim (or the cast one Magnus makes), 3" downpipe, awd swap.
- Background
- I bought my GST from the original owner with 136k miles in 2013. At the time I hadn't been in the car scene for very long and wasn't aware of the turbo models and the potential they have. Shortly afterwards I moved to Wilmington, NC and became friends with some of the guys that work at the speed shops in town. That's when I really started to look into modifying the car and got to work on getting whatever parts I could afford. I got DSMLink in 2014 and started tuning on my own. The car is still self-tuned right now and will likely stay that way until it gets a flex-fuel tune. At this point the car puts down around 280-300 whp (best guess). In February 2017 I hit 200k on the original 7 bolt and it's still going strong.
