- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- EGR Delete, 16g Evo 3 turbo,
- Mods-EMS & Logging
- AEM with NGK AFX Wideband, AEM Pro used for logging, NGK AFX AFR gauge, Street glow Boost gauge, Speed Density setup.
- Mods-Drivetrain
- Stock Transmission as of right now, ACT 2100 pressure plate, Fidanza Aluminum flywheel, street disc.
- Mods-Handling
- K Sport full coilover suspension, Galant Vr4 knuckles with Evo 8 brembo calipers all the way around. 17" Enkei Evo 8's 17x8 with 215/45/17 BFG G sport
- Parts Wishlist
- Change stock radiator and fans over to slimlines and aftermarket radiator, Oil catch can, FP exhaust manifold, re route 3 inch exhaust from between axle and body to under axle, Redo interior, switch to an FP Green turbo, Tial wastegate
- Background
- I bought this car 5 years ago and took it from having nothing done to it and rebuilding the whole car to make it what it is now. heres a list of the mods I've done since I've owned it.
-Changed suspension to full coilovers
-Switched front end from 95 to 99 Eclipse
-Changed sideskirts from talon to 99 eclipse skirts
-Ditched the wing and shaved the hatch
-Shaved pissers on rear hatch
-Installed all new kenwood speakers to replace factory oem speakers
-Installed Fidanza aluminum flywheel and ACT 2200 pressure plate with street disc
-Installed double din DVD headunit.
-Sunk HKS Turbo timer into center console and installed
-Did all maintenance on car including new timing belt and waterpump along with regular oil
changes
-Installed new front axles and tie rod ends
-swapped oem brake setup and front spindles for Galant VR4 spindles and Evo 8 Brembos
-Installed Avid Racing motor mounts
-Installed ARP head studs
-Powdercoated Valve cover, Calipers, and motor mounts
-Replaced stock injectors with Evo 8 Injectors
-Deleted EGR
-Deleted Cruise Control
-Replaced AC compressor with new one
-Installed Evo 3 16G turbo
-Installed NGK AFX Wideband along with AEM EMS
-Fixed all rust on strut towers and did bodywork and sprayed to clean up engine bay
-Reprayed entire car with the talon 2 tone using black for the roof and S2000 silver for bottom
-Replaced stock Intercooler with Evo 8 front mount and made all intercooler piping
-Tial Q blowoff valve
-Replaced MAF with Velocity stack and I am running Speed Density
-Evo 8 Enkies powdercoated Gloss Black wrapped in 215/45/17 BFG G force tires
-Replaced all front lower control arms with new oem ones
-Replaced stock clutch line with stainless steel braided line
-Replaced turbo oil feed with Stainless steel braided line
-Replaced all tensioners and pulleys when changed out waterpump and timing belt
-Front and rear strut tower bars
-Vibrant Racing Boost Controller
This is all I can think of for now......
