- Year
- 1993
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- 93 awd: XDR 2500lbs clutch, Fidanza 7lb flywheel, b/shafts elim, BC 280's, k&n, ram air intake, 3.5"maf-t, Air to Water ic, w/ short 3" full ic piping, 75mm tb, Dejon SMIM, ported/polish head, ud crank pulley, S.S. T3 header, Garret GT3582R w/ .82 a/r, 44mm Tial wg, 3" turbo-back exhaust w/ cutout, tailor wires, a/m boost, water & oil gauges, ecm link v3, translator ver. 2.02, 8 gal poly fuel cell, -8 fuel line & return, mallory 110 gph inline fuel pump, mallory afpr, FIC 1150cc inj, water/alcohol injection 300cc nozel, slim pusher fan, 160* t-stat, battery moved to trunk Ext oil cooler, Prothane motor mounts. 86 fox hatchback GT40P engine full bolt ons! 90 Talon awd dd: super 20g, 3" turbo back, 2g maf, fmic, eprom, 255hp, hard piping, PTE 1000cc inj
- Mods-Engine
- 6-bolt, ballance/s elim, flow bench ported and polished head by Green cylinder heads, stainless steel valves, Viton valve stem seals, BC 280's, BC dual valve springs & titanium retainers, ARP head studs, 4 layer metal head gasket, kevlar timing belt, 2g pistons .20" over bore, Clevite tri-metal bearings, stock polished crank, 90 oil cooler
- Mods-EMS & Logging
- Eprom, Maf-t ver. 2.02, DSM Link ver. 3, 8 gal poly fuel cell, -8 fuel line & return, mallory 110 gph inline fuel pump, mallory afpr, PTE 1000cc inj,
- Mods-Drivetrain
- built 23 spline with double syncro 2nd gear, steel shift forks, welded center diff, viscous elim, fwd pass axle, SBR twin disk clutch, Fidanza 7lb flywheel, 1 piece driveshaft, redline shock proof lube
- Mods-Handling
- 16"x7.5" Weld Racing wheels with 4 225 45r16 Nitto 555R Drag radials,
obx coil overs, 93 BIG breaks upgrade, kyb agx front struts
- Parts Wishlist
- 8.8 solid rear end, 26"x9.5" hoosier QTP slicks on 15's, dogbox, forged internal 2.3 short block, bigger turbo
- 1/4 Mile E/T
- 13.841
- 1/4 Mile MPH
- 99.580
- 1/8 Mile E/T
- 8.952
- 1/8 Mile MPH
- 80.450
- 60' Time
- 2.071
- Timeslip Details
- Track Name : Karney Raceway Park
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3100
Tires : Drag Radials
Altitude : 2130
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
- Dyno Session Details
- Nitrous : No Nitrous
