- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- K&N air filter.
Custom 4 inch intake pipe.
3in. turbo-back Megan Racing exhaust.
New "Old school" FP Red turbo.
Tial 38mm MVS WG.
Calan's V3 sealed catch can
ETS 7" street intercooler kit.
GM IAT Sensor.
OMNI POWER 4 Bar MAP Sensor.
GM flex fuel sensor.
AEM Wideband.
Fluidampr harmonic balancer.
FIC 2150cc injectors w/ delete plug .
FP Race Manifold.
Areomotive Compact FPR at 43.5psi
Wally 450 E85 pump w/ rewire kit.
-8AN fuel feed line tank to rail.
Fuel lab short fuel filter with SS E85 element.
Symborski Shifter Kit with skateboard bearings on trans.
90 oil filter housing with B&M oil cooler.
Mishimoto aluminum radiator w/ Gates racing hoses.
- Mods-Engine
- ARP L19 head studs.
OEM MLS head gasket
ARP main studs.
Revised 3g lifters.
GSC S2 cams.
AEM adjustable cam gears.
Gates Racing Timing Belt.
Kiggly valve springs.
Supertech valves.
Manley valve locks.
Manley 8.5:1 pistons.
Manley rods.
ACL rod bearings.
Clevite main bearings.
BSE w/ AMS race balance shaft kit.
- Mods-EMS & Logging
- AEM UEGO Wideband.
DSMLink V3 on speed density.
Autometer Phantom 30/30 boost, water temp, battery volts, and oil pressure gauges
- Mods-Drivetrain
- ACT 6 puck sprung clutch disk.
Southbend SSX pressure plate.
ACT Streetlight flywheel.
ARP flywheel bolts.
Shep stage 3 trans.
Prothane Mounts.
- Mods-Handling
- DGR street coilovers 7k/7k.
05-06 Outlander front brakes.
Powerslot front and rear rotors.
EBC Red Stuff pads.
JNZ ABS delete kit.
JNZ 7mm wheel spacers.
ARP extended studs.
Enkei RPF1s 17x8
Falken Azenis rt 615k 245-45/17
- Parts Wishlist
- Too many to list or afford.....
- Timeslip Details
- Sponsored Car : no
