- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT35 Variant
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- • Forced Performance JB Black HTZ 8cm ported by FP
• Forced Performance race exhaust manifold 8cm ported by FP
• Punishment Racing o2 housing (recirculated)
• Tial MVS 38mm wastegate (18psi spring combo)
• Forced Performance 4" intake + 9" K&N filter
• Magnus cast SMIM + Magnus heat barrier gasket
• Stock throttle body with vacuum deleted and fiav deleted
• ETS 5" front mount intercooler
• Tial Q 50mm BOV
• Fuel Injector Clinic 1050cc injectors
• Walbro 255 LPH HP in-tank fuel pump (rewired with 8g gauge)
• 8AN fuel hose from OEM filter to rail
• Magnus 10AN fuel rail
• 10AN from rail to fpr
• Aeromotive adjustable fuel pressure regulator #13101 (43.5psi base fuel psi)
• Stock fuel feed and return line
• 300m coil on plug setup
• Dynatech Arc-2 Ignition amplifier
• NGK BPR7eS gap @ 0.028"
• 3" custom downpipe
• 3" SRS catback exhaust
• Protane front and rear subframe bushing
• Protane side and rear motor mount
• Solid 6061 Front roll stop (made by me)
• Solid 6061 Half moon seal (made by me)
• Solid 6061 Crossmember bushing (made by me)
• AFCO 80107N Dragracing radiator with 16AN hoses
• Flex-a-lite Twin 8.5" Radiator Fans on shroud
• JMF Deluxe water overflow
• B&M Oil cooler 11x8x1.5 #70272 + 8AN hoses + 8" pusher fan
• 90 Oil filter housing #MD132912
• Optima yellow top relocated to trunk in Moroso box
• Saturn 160amp 1 wire alternator with smallest pulley from motor city
• Jay Racing Alternator relocation kit #ARK1S + Alloy steel HD braquet
• Flaming River kill switch #FR1003-2
• Stigner ProSerie pure cooper 1/0 gauge wire
• Moroso Remote Battery Jumper Terminals #74140
• Moroso Thru-Panel Battery Connectors #74145
• Aerocatch hood pin #120-2100
• Overkill Fabrication front bumper quick release kit + support
• Zaklee clear cam cover
• Calan VS3 catch can 10AN inlet and 12AN outlet
• SS Hose with AN fitting everywhere
- Mods-Engine
- • Stock head and block @ 80 000km on the clock
• Balance shafts deleted
• ARP L19 head studs @ 90lbs/ft
• ARP Cam sproket bolts #ARP-107-1002
• OEM Hydraulic tensioner, idler pulley, tensioner pulley and water pump @ 75 000KM
• Gates Racing blue timing belt #T167RB1
- Mods-EMS & Logging
- • ECMLink v3 on SD
• Autometer Elite Serie Water Temperature #5554
• Autometer Elite Serie Oil Temperature 100-260*F #5638
• Autometer Elite Serie Oil Pressure 0-100psi #5652
• Autometer Sport Comp II Boost gauge 30/30 #3659
• AEM 6in1 wideband #30-4110
• AEM Air Temperature Sensor #30-2010
• AEM 3.5 Bar MAP #30-2130-50
- Mods-Drivetrain
- • Solid 6061 Shifter base bushings (made by me)
• Bronze Shifter top pivot bushings (made by me)
• Under-hood shifter cable bushings in bronze (made by me)
• Solid 6061 Shifter bracket bushing (made by me)
• Solid 6061 Driveshaft carrier bearing bushings (made by me)
• Bearing carrier 7mm shim (made by me) 12.5mm total tickness (bushing + shim)
• DriveShaft Shop 3.5" Aluminum driveshaft
• 4 Bolts rear end
• Rear subframe stitched (153 total)
• LSD Rear differential
• Bullfab mustache bar
• Stock Transfer case
• Stock Transmission
• Stock flywheel step @ 0.609"
• XTD Stage 4 Clutch unsprung
• SS Clutch line (master to slave)
- Mods-Handling
- • Volk Racing AV3 2 pieces 17x7 ET37
• Maxxis 225/50R17
• Tein SuperStreet coilover
• AFCO Rear upper and lower control arm with Aurora AM12-T heims
• Solid 6061 bushing on lower front control arm (made by me)
• Depowered steering rack + Torsion bar welded
• GoodRidge 8pcs SS brake lines #26023
- Background
- Take a look at my build thread :
http://www.dsmtuners.com/threads/dsm4life-awd-jdm-gsr-4-91-build-thread.470307/
