Please Support Rix Racing
90turbotsi's Eclipse GSX
Mitsubishi Eclipse GSX
Apex Dunk full 3in exhaust (no cat), Fp Green(S.S. return & feed lines), Tial 44mm Wastegate, SS Autocrome FMIC, Greddy RS BOV, Magnecore 10mm wires, Aeromotive Fpr, Denso 720cc injectors, Walbro 255lph fuel pump, Earls oil cooler w/ -10 S.S. lines, Mishimoto Radiator, NGK BPR7ES
Mods-Engine
6-bolt block: 2.3L stroker with balance shafts(w/modified oil port), Weisco Pistons(.020 over); Manley H-beam rods, ACL race crank and rod bearings; MLS head gasket; ARP rod bolts, mains and head studs; HKS 272's; 1mm o/s S.S. nitride coated valves; Crower springs & retainers; ported head w/ modified oil port; Emissions/AC removed, Greddy timing and balance shaft belt
Mods-EMS & Logging
DSM Link; Auto Meter 52mm boost, Pyrometer and oil pressure gauges, AEM Wideband UEGO
Mods-Drivetrain
ACT 2600, ACT street light flywheel, Full Red Prothane motor mounts, Aluminum shift-linkage bushings; Hard shifter-base washers; B&M Short Shifter, full stainless clutch-line w/ pressure reservoir removed. B.G. Syncroshift II transmission fluid, Red line shock proof transfer case and differential fluid.
Power Slot big Brakes, Goodrich S.S. brake lines, ABS removed, Eibach pro kit 3 way adjustable, Front strut tower bar, new mitsu ball joints and rear control arms, Rota P45f, Falken RT-615's
Parts Wishlist
Shep trans in the future
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
90turbotsi
More in 1G DSM
Share this Vehicle
