- Year
- 1993
- Model/Trim
- Mitsubishi Eclipse GSX
- Mods-Bolt-on
- 2g maf, cx racing short route fmic,turbo xs rfl bov, small 16G turbo, fic 650 inj, walbro255, walbro rewire, 3" turbo back exhaust, 3" test pipe, forge in cabin boost controller. 2.25 inter cooler piping, mishimoto fans an shroud,1 g poly mounts ported o2 housing
- Mods-Engine
- 6 bolt block , .040 over pistons, balance shaft delete, dsm graveyard steel valves. viton valve seals, ported and polished, a small 16g turbo ported, ported 7cm hotside. with ported o2 housing, 2 g exh manifold, hks 264 cams
- Mods-EMS & Logging
- ECM link v3, converted non eprom ecu, running 2g timing map. innovate Mtx- l wideband, 30psi boost gauge, oil press gauge. 2g maf. Walbro 255 lph rewire. Fpr
- Mods-Drivetrain
- 4 bolt rear end, lightweight flywheel.
- Mods-Handling
- Eibach pro lowering springs, kyb gr 2 struts 2g wheels, vibrant front strut tower brace
- Parts Wishlist
- Set of 272 cams, 3G lifters, holset turbo
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
