Please Support Kiggly Racing
907gs-t 98 Eclipse GS-T
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
T28
Automatic
Build Type
  1. Street
K&N FIPK with a Custom Heatshield,Injen Air Intake,Dejon UICP & LICP,Forge BOV,Hahn Racecraft SMIC,Black AEM Fuel Rail with Liquid Filled Fuel Pressure Gauge in Blue,Blue B&M Fuel Pressure Regulator,RC 550cc Injectors,Optima Red Top Battery,Hayame Blue Fuse Box Cover,JVT Racing Aluminum Radiator,Hayame Chrome Radiator Brackets,Custom Aluminum Radiator OverFlow Tank,Gates Racing Radiator Hoses Upper & Lower in Blue,Greddy Radiator Cap,Silicone Vacuum Line Kit in Blue,Blue Mitsu Valve Cover,Mirrored Blue Mitsu Oil Cap,Walbro 255 lph with Rewire Kit,Unorthodox Underdrive Pulley Kit in Blue,FP BT-28 Ported by SBR,JNZ Oil Return Braided S.S. Line,FP Exhaust Manifold,S.S.Tubular Recirculated O2 Housing,Borla 3inch Downpipe,OBX High-Flow 2 1/2inch S.S.Cat,SR-S 3inch S.S. Cat-Back Exhaust,NGK Spark Plugs with a Spark Tech C.O.P. set-up
Mods-Engine
ARP Hardware throughout,Cometic Head Gasket Kit,Cometic Top End Gasket Kit,Gates Racing Kevlar Timing Belt,Head Rebuilt,New OEM Timing Belt Tensioner & Pulley kit,New OEM Crank Position Sensor,New OEM Water Pump,New Magnetic Oil Drain Plug,New Zak Lee Clear Upper Timing Belt Cover,& a New STM Oil Dip Stick & Tube with Spring & a 170 degree thermostat.All these Item's were replaced at 140,250 miles the same time when the Head was Rebuilt. Going into my lower end Rebuild : Orbit oil pump, Brand New stock oil cooler, MLS head gasket, Balance shaft delete kit, Wiseco forged pistons 85.5 mm. , Manley H-Beam connecting rods with ARP Bolts, Clevite oversized main and rod bearings,Polished and Balanced 7 bolt crank / Rotating assembly balanced & a Rebuilt FP BT-28.
Mods-EMS & Logging
Greddy Profec B-spec II Electronic Boost Controller in Black,Greddy Type-II Turbo Timer in Black & Greddy P-N-P Turbo Timer Harness,Apexi SAFC-II in Black,Boomslang P-N-P SAFC-II Wiring Harness,Autometer Lunar-Boost/Vacuum,Oil Pressure,Volts,Water Temp,Trans Temp Gauge's & Innovate Wideband LC-1 with DB Gauge in Blue. Also have a Compustar Auto-Start.Will be running DSM Link in the near future. Still need to get a Prosport EVO EGT gauge in Blue.
Mods-Drivetrain
Stock for now
Might get Translab Shift kit for Spring 2017.
Megan Racing Gun-Metal Grey Front & Rear Upper Strut Bars,Godspeed Chrome moly 21.06mm Front & 19.00mm Rear Sway bars,Right now running MB Rims with 215/50/17 Toyo Eclipse tires. Also did a rear wiper & radio antenna delete.
Parts Wishlist
All That i don't have.
1/8 Mile E/T
9.329
1/8 Mile MPH
97.590
Timeslip Details
Fuel Used : Pump gas
Tires : Street Radials
399.0 lb/ft
Dyno Session Details
Turbo : T28
Boost : 15
  • 907-gs-t-albums-eclipse-gs-t-upgrade-picture42t-greddy-profec-spec-ii-remote-switch.jpg
  • 907-gs-t-albums-eclipse-gs-t-upgrade-picture46t-innovate-lc-1-db-blue-gauge.jpg
  • Like
Reactions: RiCeR
907gs-t
More in 2G DSM
Share this Vehicle
