- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- HX40
Upgraded 67mm Turbine
Morrison Fab Small Runner T3
.70ar T3 BEP hot side w/ PTP Blanket
Morrison Fab 3" v-band
44mm Tial WG
3" Exhaust
4" K&N Filter w/ 4" Intake Pipe
FIC 1250's
Walbro 470 lph HP rewired
-6 AN Fuel Lines and Fittings
Aeromotive FPR kit
JMF Race Intake
Spark Tech COP
Mac 4 Port Elec Boost Controller
Garrett Intercooler
2.5" Short Route Piping
1 Piece Upper IC Pipe
Tial 50mm BOV
Megan Racing Aluminum Radiator
2 - 12" Derale Fans
- Mods-Engine
- .020 over bore
Cleavite Bearings
Eagle H-beam Rods
Wiseco 8.3:1 Pistons
OEM Oil Pump w/ Straight Cut Gears
OEM Oil Cooler Setup
ARP Main Studs/Bolts
Ported 1G head w/ Kiggly HP Springs
ARP Head Studs
MLS Head Gasket
Gates Timing Telt
GSC S2s (274's)
-10AN Valve Cover Breather Lines
-10AN 2 Port Vent/Baffled Catch Can
- Mods-EMS & Logging
- ECM Link V3
Speed Density
Innovate LC-1 WB kit
Megan Racing Boost, Egt, and Oil Pressure Gauges
SparkTec COP
Dynatek Arc 2
JMF Battery Kit w/ Braille Battery
ECM Link Boost by Gear
- Mods-Drivetrain
- TRE Built AWD Trans w/ Welded Diff
TRE Built 300M X-fer
TRE Built Evo Rear Diff
DSS 3" Aluminum Driveshaft
Stainless Braided Clutch Line from Master to Slave
SBC SS-X Clutch
Solid Shifter Base Bushings
Solid Shifter Cable Bushings
Poly Bushings
- Mods-Handling
- KYB AGX Struts
Front and Rear Strut Braces
Megan Racing Springs
91 3kgt NT EBC USR Slotted Rotors & Red Stuff Pads
Rebuilt Rear OEM Calipers w/ EBC USR Slotted Rotors & Red Stuff Pads
JNZ Tuning Stainless Braided Brake Line Kit
Ingalls 1G DSM Adj Rear Camber Arms
Poly Bushings
Evo Wheels
- Background
- I have always loved the DSM. Started with a 90 fwd laser project but got the awd and swapped focus. Dealing with the increased power in one area and the brakeage in another. Typical DSM love hate.
- 1/4 Mile E/T
- 11.837
- 1/4 Mile MPH
- 123.52
- 1/8 Mile E/T
- 7.786
- 1/8 Mile MPH
- 96.94
- 60' Time
- 1.867
- Timeslip Details
- Top Gun Raceway
Elev - 3963'
Car -
2900lbs w/o driver
91 Pump
@24lbs of Boost
No No2
Kuhmo Ecasta Radial Tires
- Dyno HP
- 542.4 whp
- Dyno TQ
- 439.8 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Street 2 Sand, Reno NV
- Dyno Session Details
- Took us 5 runs and taking a lot of fuel away. Ended with the following:
32lbs boost
91 Oct
No meth
No No2
