- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Fuel Lab AFPR, -6AN Russell Pro Classic Fuel Line (Supply & Return) Powder Coated Valve Cover and Intake Manifold, Megan 3" Downpipe,
- Mods-Engine
- EvoIII 16g turbo, Stock head rebuild. Gates timing kit w/pulleys, ARP Head Studs, New OEM head gasket kit, New OEM Exhaust Manifold Studs, New Turbo to 02 bolts, New 02 to Downpipe Bolts, Complete EGR Delete, STM Blockoff Plate, A/C Delete, Cruise Control Delete, Fuel Pressure Solenoid & Evaporative Emissions Purge Control Solenoid Delete, Winshield Wiper Delete, Hallman Pro Boost Controller and New Oil Pressure Sending Unit. Brad Penn 10w30 Motor Oil. NGK Spark Plugs and Wires and Hallman Pro boost controller.
- Mods-EMS & Logging
- N/A
- Mods-Drivetrain
- All stock right now. Redline MT-90 Tranny Fluid and Redline Heavy Shockproof Gear Oil for transfer case and differential.
- Mods-Handling
- Junk aftermarket no name wheels. (came with car when I bought it) All stock otherwise.
- Parts Wishlist
- DSMLink, AEM wideband, Digital Boost Gauge, Tial External Wastegate, SS 02 housing with vented wastegate dump, GM MAF w/ MAFT, BOV (vented), 1200+ injectors, e85 400whp capable fuel pump.
- Background
- Right now my goal is to get the car running and driving as if it were new. Once, that is accomplished, I will look more into tuning the car and turning up the boost. This is just project/toy car so time isn't really a factor. I just want to do it right the first time around.
