- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT30 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- FP 3052 w FP Oil Filter (GT30 Variant)
FP exhaust manifold
Tial 44mm vband wastegate open dump
Vband 3" turboback
PTE 1000cc injectors
Additional 6 stock 450's
Aermotive A1000 AFPR
-10 braided fuel feed with -6 return
Dual walbro 255s Hardwired
Eldelbrock fuel filter
Omni 4 bar map + gm iat
Speed Density Tuned on Ethanol
NGK wires + bpr8es plugs
Fluidyne 2g radiator w single slim fan
Kirkey Seat with 5 point harness
5-600lb weight reduction
No ac, ps, abs, interior, bumpers, emissions, etc
Homemade poly motor mounts
- Mods-Engine
- Low mileage jdm 6 bolt longblock
ARP L19 Headstuds
DKS 272 cams
GSC power lifters
New oem timing components, gates timing belt
Rebuilt throttle body w fiav block
OEM MLS Headgasket
New Gaskets and Seals
- Mods-EMS & Logging
- Ecmlink v3
AEM Injector Driver Box
Lc1 narrowband sim
Electronic Fuel Pressure Gauge
Wideband Gauge
Boost Gauge
Speed density
- Mods-Drivetrain
- ACT streetlite flywheel
ACT xtreme pp
ACT 6 puck unsprung clutch
Redline fluids
- Mods-Handling
- BBS 16" lightweight wheel 16lb
KYB gr2 front
KYB agx rear
Eibach lowering springs
front and rear strut bars
solid shifter base and cable bushings new brakes
- Parts Wishlist
- Poly bushing set
Lightweight driveshaft
- Background
- Got it as a budget sleeper car to get into the 10's.
