Street Build 2gjlc's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
Holset HX35 8 blade .55AR bolt on housing
Punishment Racing recirc o2 housing
Tial MVS wastegate
FP exhaust manifold
FP Intake pipe
ETS Street Intercooler
Curt Brown Ported EVO 3 intake manifold
Buschur Racing 2.5" throttle body elbow
RRE downpipe, Apexi mid pipe and English Racing Vibrant twin tip muffler install
FIC 1150's
DW300 fuel pump
Greddy Type S BOV
Prothane motor mounts (all),
Snow Performance Stage 2 Water Meth Kit
fuel lab fpr
Mishimoto X line radiator
Mods-Engine
Kiggly Beehive springs
GSC S2s
Wiseco 8.5:1 pistons
Manley stroker crank
Howard(MAP) rods
OEM MLS head gasket
Fluidamper harmonic balancer
ARP L19 Head studs
ARP main studs
Evo IX OFH w/ oil cooler
Mods-EMS & Logging
Evo 8 ECU
ECU flash
EvoScan
AEM X series boost gauge
AEM wideband
IR 3 Port solenoid
Omni 4 bar MAP sensor
Mods-Drivetrain
ACT 2600 Pressure Plate
South Bend segmented Kevlar disc
ACT Streetlite Flywheel
Steel Braided clutch line
Energy Suspension shifter base bushings
Speed Source shifter cable bushings
Split motorsports rear diff poly bushings
Bulfab cross member
Feal 441 Coilovers with Swift Springs: 11k front/6k rear
Tires: Michelin Pilot Sport A/S 3+ 245/40/18
Evo X Enkei's 18x8.5
CTS V Front Calipers
Evo 8 Rear Calipers
3g Brake Master Cylinder
SS brake lines
Paul Volk rear toe arms
Parts Wishlist
TRE Rebuilt transmission
Built Transfer case
torque solutions driveshaft bushings
tubular front and rear sub frames
Evo Rear Diff
Background
Purchased car with a bent rod. Bought a stroker short block and have been fixing the mechanical and electrical issues the car had. Want to make this a DD low 11 second car.
1/8 Mile E/T
7.816
1/8 Mile MPH
93.05
Timeslip Details
Time slip is from when car was making mid to low 300 whp.
Dyno HP
462 whp
380 lb/ft
Dyno Type
Dynapack
Dyno Shop Name
Road Race Engineering
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : 91 Oct Pump gas
Turbo : HX35 .55 bolt on housing
Boost : 28
Meth injection 100% meth
10 gal meth nozzle
  • Like
Reactions: dsm_ribbitpoison
2gjlc
More in 2G DSM
Share this Vehicle
