2GeNTSi's Talon TSi
Eagle Talon TSi
TD05H-14B Turbo | 3" Custom Catback w/ Magnaflow Muffler | 3" ExtremePSI Downpipe | SBR/DPH Full IC/Intake Piping | K+N FIPK | Aluminum Radiator | Joe P MBC @ 14psi | Rebuilt 1G TB w/ FIAV Bypass | Crushed 1G BOV | 2G Non-Cruise Throttle Cable | 180 Thermostat | Walbro 190lph Fuel Pump | NGK Wires | NGK BPR6ES
Mods-Engine
Rebuilt/Swapped 6-Bolt | Clearwater Stage I 6-Bolt Head | ARP Headstuds | Mitsubishi Metal HG | Balance Shaft Eliminated | Mighty Max OFH | ITM Revised Lifters
Mods-EMS & Logging
Greddy Turbo Timer | Autometer Ultra-Lite Boost Gauge | ELM327 Bluetooth OBDII w/ Torque App
Mods-Drivetrain
Stage II TRE Transmission | ACT 2100 w/ Street Disc | XACT Streetlite Flywheel | Symborski Shifter Bushings | Under-Hood Shifter Cable Bushings | B+M "Clone" Short Shifter | SBR SS Clutch Line
Tokico Springs | Tokico Illuminas | Prothane Motor Mounts | RRE Front Camber Kit | RRE Rear Camber Kit | 97-99 GS/T Bronze Wheels | Kumho Ecsta SPT 225/50/16 | Brembo Cross Dimpled + Slotted Rotors | F - Hawk HPS Pads / B - PBR Metal Master Pads | Techna-Fit SS Brake Lines
Parts Wishlist
DSMLink, Rota D2 16x8 +40, Meagan or D2 Coilovers, Custom FMIC, F+R Swaybars, F+R Strutbars, Lower Tie Arm, and fixed oil leaks!
1/8 Mile E/T
7.734
1/8 Mile MPH
91.760
Timeslip Details
Tires : Street Radials
346.9 lb/ft
2GeNTSi
More in 2G DSM
Share this Vehicle
