2geclipse565's Eclipse GSX
Mitsubishi Eclipse GSX
Automatic
EVO3 16G turbo 3inch down pipe and exhaust with test pipe, FMIC, NGR atmospheric dump blow off valve. It has the evo fuel pump, with 750cc FIC fuel injectors, and a manual boost controller. 96-amp GM Saturn alternator with dual 12" slim fans
Mods-Engine
6 bolt conversion 1g head, throttle body ARP rod bolts and head studs, cometic head gasket.
Mods-EMS & Logging
98 ecu with ecu flash currently running a conservative tune
Mods-Drivetrain
W4A33 Automatic 4-speed transmission was fully rebuilt less than 500 miles with new clutches, steels, shift kit, and end clutch kit. The stall was rebuilt at the same time and restalled to close to 3,000 RPM
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
2geclipse565
More in 2G DSM
Share this Vehicle
