- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse N/T
- Mods-Bolt-on
- AMM intake,billet fuel fuel rail, Mpx 60mm TB,Gt35r,Tial bov, 38MM Tubonetics waste gate, Symtech 420a turbo manifold,3inch turbo back exhaust,with 3in electric cutout,MSD coil, MSD 8.5 mm plug wires,NGK plugs,AEM cam gears, solid MM inserts.dual Walbro 255 fuel pumps, 6an feed line
all vac lines done in -4an fittings.
- Mods-Engine
- block mods- Callies 2.2 stroker crank, CP 40 over pistons,total seal rings,eagle rods, Melling high flow oil pump,Clevitte 77 rod and main bearings,ARP main and head studs,
cylinder head-crane 12 cams,crane valve springs,1mm SS over sized valves , mild port and polish head,DCR oil mod
- Mods-EMS & Logging
- Autometer EGT gauge, Autometer boost,oil,water gauges, turbo timer,innovate LC-1 wide band, , MSNS ms2 3.0 Full standalone.. 1600cc blue max injectors.
MPx IAC,
- Mods-Drivetrain
- Southbend clutch, 6 puck, SS pressure plate with aluminum flywheel
OBX lsd, SS clutch line.Megan short shifter, prothane plate bushings, Home made rod brake. Roller bearing shifter cable mod.ARP wheel studs.
- Mods-Handling
- KYB 5 way struts,Eibach sportlines,8pt cage,OBX front strut bar
- Parts Wishlist
- Axles, stronger trans....
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 370.0 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- performace driven
- Dyno Session Details
- Fuel Used : E85
Boost : 20
