1g daily driver build
Ownership Status
Currently Own
Eagle Talon TSi
Turbo Type
20g
Drivetrain
AWD
Build Type
  1. Street
Boost gauge, a/f gauge, 2 row radiator, manual steering rack, jmf small battery kit, prothane motor mounts, oil catch can, 3" exhaust, self built and balanced 20g (extended tip billet Wheel), 46mm wastegate gate, wrapped v-band downpipe, 3g mas, vrsf intercooler kit, walbro 255lph fuel pump, Adjustable fuel pressure regulator
Mods-Engine
1g rods/2g pistons, shot-peened rod, arp rod bolts, arp head bolts, balanced rotating assembly, acl tri-metal bearings, bc valve springs w/ stock retainers, stock cams, 3g lifters, balanced shaft delete, ported stock turbo manifold w/ shield, pte 1200cc injectors, modified 1g bov
Mods-EMS & Logging
ecmlink v3, aem wideband
Mods-Drivetrain
4 bolt rear end, stock flywheel, xtd 6 puck disk, xtd pressure plate, stock 92 trans/ t-case, 2g weighted shift knob
Extended wheel studs. Rx7 16x8, 245/45/16 tires, 10mm spacers (rear), eibach lower springs, agx rear strut, kyb gr2 front struts, braided stainless steel brake lines
Background
I wanted to create a daily driver that retained a stock like appreance, such as the a/c and cruise control while still being in the 350 whp to 400 whp range
Talon43219
More in 1G DSM
Share this Vehicle
