Please Support RTM Racing
Street Build 1999 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
HX-40 with Billet wheel
Archer Fabrication T3 Bottom Mount
Tial MVR 44
JM Fab Intake
VRSF FMIC (Short Route)
4" Extreme PSI Intake
HKS SSQV IV (Limited Gun Metal)
Boomba Racing MBC
VW Aluminum Half Radiator
FueLab "515" Fuel Pressure Regulator
FueLab "818" Fuel Feed Upgrade Kit
Walbro 255
Avid Racing Tuner Series 4-Piece Motor Mount 75A
S90 Billet Throttle Body (70mm)
Megan Racing Short Shifter
3 Port 10AN Catch Can
FIC 1650 High Z
Mods-Engine
Built By Strictly Performance Motorsports
7-Bolt 4G63
Bore - .020
ARP Head Studs
ARP Main Studs
Manley H-Beams with ARP Rod Bolts
Manley 8.5:1 Comp Pistons
Gates Blue Racing Timing Belt
Gates Water Pump
ACL HX Bearings
OEM Oil Pump
OEM Timing Components
BSE Kit
Stainless Steel Valves
Manley Single Coil Valve Springs
3G Revised Lifters
OEM Camshafts
OEM Cam Gears
Every Bolt and cover is Brand New OEM
Mods-EMS & Logging
Speed Density
AEM (Water Temp, Boost)
Innovate MTX Wideband and Oil Pressure
DSMLink V3
Mods-Drivetrain
Evo 3 Transmission Built by White Shed Speed
Evo 3 Transfer Case
Evo 3 Rear LSD Differential
Evo 3 Axel Cups
Fidanza V2 clutch
Fidanza Lightweight flywheel
SS Clutch Line (Master to Slave)
ABS Delete
STM Driveshaft Solid Bushings
Rays Gram Lights 57
Federal Racing 595-RS-RR
Evo X Front Brembo
Evo IX Rear Brembo
Volk Metal Rear Lower Control Arms
Volk Metal Rear Trailing Arms
Volk Metal Rear Toe Arms
Mach V Rear Sway Bar
Mach V Front Sway Bar
Kenny07
Comments
3
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
