Please Support Kiggly Racing
Street Build 1998 GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Automatic
Build Type
  1. Street
  2. Drag Race
PTE Next Gen R Turbocharger
Morrison consolidated divided T4 exhaust manifold
2X TiAL 38mm MVS wastegates
Dry Nitrous kit used to get on converter and 60ft (~75 shot)
Treadstone TR1045 FMIC
TiAL Q BOV
ECMLink v3 with SD, e85/x85
Dynatek ARC-2
Vamos bolt in 2g fuel cell
Magnafuel MP-4303 fuel pump
Magnafuel 74 micron pre-pump filter
Alpha 2600cc fuel injectors
FIC fuel rail
FUELAB post pump filter/ 40 micron SS filter element
FUELAB AFPR
-8AN feed/-6 return
BoostedFab chromoly crossmember
STM small battery tray w/ Odyssey PC680
Audi Vacuum pump
Mods-Engine
Force Engineering built 6 bolt bottom end using R&R Al Rods, Kiggly girdle, and 10:1 Wiesco HD pistons (22mm pins)
Force Engineering machined cylinder head
Magnus cast intake manifold
AEM Tru-Time cam gears
GSC billet S2 camshafts
Kiggly beehive HP springs & Titanium Retainers, shimmed for higher boost application
Kiggly HLA
Kiggly 6 bolt 2 tooth crank sensor kit
ARP L19 head studs
SCE Vulcan cut ring Head gasket
BSE
Mods-EMS & Logging
ECMLink v3 S/D, Forced Four SMART 100.1 Shift box, AEM Boost gauge, AEM X Wideband, Auto-meter digital trans temperature, Auber digital oil pressure display, OHM Racing engine harness
Mods-Drivetrain
Liberty's Gears straight cut transfer gears
Kiggly 5 friction front clutch pack
Raybestos Stage-1 RED rear clutch pack
TransLab shift kit
Welded center differential
Precision #6 tq converter
Kiggly "6-bolt in a 2g" adapter plate
Kiggly Flexplate
Forced Four SMART 100.1 Shift box with custom harness
TruCool trans cooler w/ fan
JB built 300M transfercase with JB Designs transfer case brace and Magnus billet bearing cap
DSS 3.5" 950hp Al driveshaft with upgraded SONNAX billet slip yoke
Vamos 2g drive shaft loop.
DSS stage 4 "800hp" rear axles
Frontline Fab 2g billet rear diff cover
Frontline Fab billet rear diff cover
Volk Metal Craft solid rear subframe bushings
Volk Metal Craft adjustable rear toe arms
Prothane bushings on all rear suspention components
New OEM front knuckles and control arms.
New for 2024:
Morrison Fabrications consolidated divided T4 exhaust manifold
PTE Next Gen R turbo
NDD Manual steering rack
10 point 8.50 cert cage from Red Rocket Racing
MK3 VW "tucked" Al radiator
Absolute Performance Billet Forward basket- in production
Circle D bolt together tq converter - in R&D, slated for a mid-end of summer production as of now.
KYB AGX adjustable shocks, Eibach Pro kit springs, STM's rear camber kit, Motegi Traklite 17x8" wheels with Federal 595 RS-RR 245/40-17 for street... ---15x7 ROTAS with Hoosier D06 Drag Slicks.
Parts Wishlist
Kiggly Billet Front Clutch Basket/Drum
Kiggly straight cut planetary gear set- In R&D
Magnus Billet Transfercase gears
Dyno Video Link
Watch Video
spoolinpos
Comments
4
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
