- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- V1 68HTA Ported by @pwee05 (Greg Byers)
FPRace Exhaust Manifold
Hotside ceramic coated by Detective Coating
JMFab Recirculated 02Housing
Apexi Full Downpipe and Catback
Forced Performance 4 inch "Mongoloid" intake
Punishment Racing "budget" FMIC kit
Deatschwerks 340 lph Fuel pump w/ STM Rewire
FIC Bluemax 1250 injectors
- Mods-Engine
- Comp Cam "272" Intake and Exhaust
Stock Valvetrain
4g64 2.4l engine block
Wiseco 9:1 Hypereutectic Pistons
Eagle H-beam rods
Stock 2.4 crank
Best Western Swapped by the best "Pit Crew" ever
- Mods-EMS & Logging
- EcmLink V3 w/ Speed Density
Zeitronix Zt-2 with LCD display
STACK instruments 30 PSI Boost gauge
- Mods-Drivetrain
- BW swapped "Mystery clutch disk"
Fidanza 3.2 pressure plate
ACT Streetlite Flywheel
Stock Trans and Xfer-case
Swapped rear LSD unit
- Mods-Handling
- Magnus Motorsports Tubular rear subframe w/ RM DSM swaybar, Whiteline HD endlinks
BlackGST front aluminum subframe bushings w/ RM DSM swaybar
Poly bushing everywhere else up front
Compworks Fender Braces
BCRacing BR+ Type coilovers
SSR Type C 17x8.5 wheels
Evo Brembo swap front and rear
Adams Rotors Drilled/slotted Evo discs
Evo Steering wheel
- Parts Wishlist
- Curt Brown wheel bearings
Curt Brown ported head
2 piece brake rotors
TMZ built Trans & Xfercase
DSS driveshaft
TedSpec tune
