- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse N/T
- Turbo Type
- 14b
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- -14b Turbo, Ported and Polished
-Hahn Big FMIC
-SS Log Style Turbo Manifold
-Custom Downpipe
-3 Piece Mandrel Bent IC Piping
-1g BOV
-Tial 38mm Wastegate
-SS Oil Lines
-Walbro 255lph Fuel pump
-Fuel pump Rewire
-Vortech 12:1 FMU
-3in N1 Exhaust
-Prothane Rear Engine Mount Insert
-ITM Water Pump
-Melling Oil Pump
-Parts Dino. Mechanical Timing Belt Tensioner
-AF/X 30% Underdrive Pulley
- Mods-Engine
- -JE 8.8:1 0.020 Overbore Pistons
-Eagle Rods
-Polished Crankshaft
-Balanced Rotating Assembly
-Clevite 77 Main/Rod Bearings
-MLS Headgasket
-ARP Headstuds
- Mods-Drivetrain
- -Symborski Shift Kit/Underhood Kit
- Mods-Handling
- -GST Rims
-Goodyear Eagle RS-A Tires
-Brembo Cross Drilled Front Rotors
-Brembo OE Rear Rotors
-Axxis MM Ceramic Brake pads
-Front and Rear Strut Bars
