- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- - Evo 3 swapped engine (built block)
- Evo 3/RVR Intake manifold (1g throttle body)
- Evo 3 header manifold
- Evo 1 16g (49178-01470)
- Apexi down pipe/ cat back (3 inch)
- CAS rewire
- OEM Fuel pump (rewired)
- VRSF FMIC, CX J-pipe, 1g BOV,
- Mishimoto two row aluminum radiator
- Mishimoto 62 F thermostate
- Mods-Engine
- - JDM Evo 3 Swap
- Evo 3 head cylinder (Evo 9 valve springs and retainers, Viton valve seals
- Revised 3mm Lifters
- K stamped Camshafts
- ARP Head studs and MLS head gasket
- Evo 9 pistons stamped E9k1
- Mods-Drivetrain
- - ACT 2100 Clutch (with OEM flywheel)
- LSD differential
- Red Line transmission/ shock proof gear oil
- Mods-Handling
- - BC Racing coilovers
- Energy suspension bushings
- non-brand slotted /drilled rotors
- Parts Wishlist
- - 255 FP (with fuel lab AFPR)
- DSM LINK
- Injectors
- functional catch cans ( upgrade PVC system)
- Background
- Bought it in 2014 non-running/ incomplete from the junk before the title was switched over and scrapped, I swapped in a new motor, bought used interior/exterior pieces and engine components ect. slowly putting this vehicle back together in to make it semi-roadworthy. this is no where near complete but someday it will.
