- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Dejon fmic setup. Dejon intake with KNN filter. 16turbo with an drain and ss feed. vc breather extended to vented catch can. PTE 680cc injectors. Walboro 255 fuel pump. snow performance methanol injection kit. 50/50 mix. Dodge mod 1gbov. Apexi 3 inch exhaust with silencer.
- Mods-Engine
- 3G lifters. cometic MLS headgasket. ARP headstuds.
- Mods-EMS & Logging
- keydiver stage 3
- Mods-Drivetrain
- half rebuild trans. new clutch fork, ACT 2600 clutch, OEM throwout bearing, replacement pivot ball.
- Mods-Handling
- KYB agx struts rear poly bushings
- Parts Wishlist
- Raybestos front end kit. Timing belt cover gasket set and main seals.
- Background
- Needs to be maintained. eventually 6 bolt swap.
