- Ownership Status
- Currently Own
- Vehicle
- 1993 Dodge Colt
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- S3 camshafts, kiggly beehives, adj, cam gears, evo316 w/ evo o2 w/ 3" exh with e-cutout, 3" intake pipe, AEM meth v2 kit, 255HP w/ rewire, racing timing belts, 785cc FIC injectors, Evo 1-3 full aluminum FMIC kit
- Mods-Engine
- Stock 6 bolt head and block (retained balance shafts)
- Mods-EMS & Logging
- Eprom w/ ostrich and tunerpro RT running Sweedensity. Autometer Boost, Innovate A/F, autometer water temp, oil temp, oil press and exhaust temp.
- Mods-Drivetrain
- Stock 2g turbo FWD trans, 1g AWD axles. ACT 2100 w/ act sprung 6 puck
- Mods-Handling
- Eiback sportlines, kyb struts, front and rear tower bars, lower rear tie bar, poly bushings
- Parts Wishlist
- Big Turbo setup, stroker motor, Swapping in Evo 1 floorpan/rear frame rails (stock look), swapping over complete evo drivetrain/suspension/fuel tank etc etc..
- Background
- initially built it 10 years ago, time to make some power and traction. Would like to soon be going to a Big Turbo setup, stroker motor, Swapping in Evo 1 floorpan/rear frame rails (stock look), swapping over complete evo drivetrain/suspension/fuel tank. Currently (spring 2015) the car is undergoing a overhaul, initial 350 WHP build on stock bottom end going FWD for the 2015 season.
