- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Galant VR-4
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Everything was done on the car at 183,642 miles unless otherwise noted
Audio:
Pioneer Headunit w/ AUX
JL Audio rear deck and door speakers
Rockford Fosgates in the dashboard
Interior:
custom floormats
EVO 8 front and rear seats
4 point racing harnesses
nardi steering wheel
freshly dyed carpet
gauges hidden in glove box
89 underdash with pocket
Refurbished stock shift boot
Rear deck dyed black
Rear Speaker covers replaced with Misfits Cloth
Custom VR4 Shift Knob - 194,352 miles
89 Manual Seatbelts - 199,453 miles
ThreeSpeed harness bar - 202,621 miles
Exterior:
JDM Front Bumper - 202,477 miles
JDM Rear Bumper - 201,421 miles
JDM RS Hood
JDM Rear 1/4 Windows
JDM Clear Corner
JDM Door Stickers
Removed wing
3rd brake light installed on rear deck
removed antenna
chrome grill
93 clear headlights - repaint - 202,477 miles
Badge Number Sticker
4WS Sticker
Rain Guards
MMC badge
Red VR-4 badge
Thule roof rack - put on and removed as i need it.
Thule Roof rack fairing
Thule Snowboard racks
window sticker
All emissions are removed.
ABS has been deleted.
No A/C.
Front wheel wells re-rubberized.
- Mods-Engine
- engine:
2g pistons/1g rods
evo 8 valves, springs & retainers
MLS head gasket
arp head studs torqued to spec
revised 3mm lifters - 186,231 miles
BSE Kit
Forward facing oil filter housing
Unorthodox Aluminum Crank Pulley - 194,543
Prothane Red Motor Mounts
HKS Clear Timing Cover
Weapon R catch can - 200,732 miles
Black Top CAS - 202,136 miles
vacuum distribution block - 202,621 miles
fuel and ignition:
Custom trunk battery tray - 202,231 miles
D-51 series Optima Yellowtop - 201,642 miles
AEM 340 in tank fuel pump - 202,136 miles
Fuel pump re-wire
denso 780cc injectors
full throttle FPR w/ gauge
new oem fuel filter - 191,943 miles
NGK Copper BPR6ES - 195,322 miles
COP Setup - 200,732 miles
Devils Own Meth Injection 7GPH Nozzle - 191,943 miles
91 octane
intake and exhaust:
Forced Performance exhaust manifold
Manifold Blanket - 202,467 miles
taiwan EVO III GT 16G turbo
2.5" intake pipe with a mushroom top filter
2G o2 housing
3" turbo back exhaust, no cat with dynomax VT muffler
29"x9"x3" intercooler - 202,467 miles
Greddy Blow off Valve
2.5" aluminum intercooler piping made to be as short as possible
GM IAT
OMNI 4 bar MAP sensor
IR boost controller(linked into ECMLink)
rebuilt throttle body
FIAV block off - 191,943 miles
New Biss with o-ring
all new gaskets
full heat shields
Cooling:
new OEM radiator - 198,843 miles
2 12" slim fans
AISIN OEM water pump - 195,785 miles
180 degree thermostat - 195,785 miles
Mishimoto Radiator Hose - 199,532 miles
fully flushed and back flushed system - 195,785 miles
- Mods-EMS & Logging
- Prosport - boost, oil pressure and wideband
Blitz TT in underdash pocket
ECMLink V3 on S/D
- Mods-Drivetrain
- short throw shifter
Rebuilt shifter assembly - 202,467 miles
Hardened washers for shifter base - 202,467 miles
Fresh Clutch fluid - 194,421 miles
OEM Throw-out bearing - 202,467 miles
Rebuilt used transmission - 202,467 miles
FX 2200LB PP - 202,467 miles
FX Multi-friction Race disc - 202,467 miles
resurfaced ACT aluminum flywheel - 202,467 miles
apr flywheel bolts
rebuilt aluminum transfercase
rebuilt driveshaft w/ carrier bearings 186,973 miles
Redline 75w90 & heavy shockproof - 202,477 miles
- Mods-Handling
- 4ws intact
Enkie 16" Rims w/ Kumho Ecsta XS 225/50ZR16 - 202,900 miles
Evo 9 MR Suspension(19,xxx miles) - 198,843 miles
Energy bushing kit
Stock rear pads - 191,943 miles
Rear rotors - 191,943 miles
front strut tower bar
Rear Strut tower bar - 195,437 miles
Stoptech Slotted rotors - 201,421 miles
Stoptech Performance pads - 201,421 miles
Wheel Bearings - 201,421 miles
Moog Steering rack boots - 201,421 miles
Moog sway bar end links - 201,421 miles
Energy Sway bar bushings - 201,421 miles
Energy tie rod and lower ball joint caps - 201,421 miles
Non-ABS proportioning valve - 201,421 miles
- Parts Wishlist
- PTE 6152
PTE 1000cc injectors
Paint Job
- Background
- i bought this Feb. 2012, built it till May 2013 and have been daily driving it since and loving every second. for the whole story read this. http://www.galantvr4.org/ubbthreads/showflat.php?Number=1050150&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1
